Questions: I'm upgrading from a Passat to an A6
I've found a 2001 2.7t A6 and I'm leaning toward going with it over a Passat (my last Passat was just totaled). I'm comfortable working on the VW, but I've never messed with an Audi. I've always shied away from Audis because, although I could by one, I couldn't afford the maintenance. Are A6s user friendly, or should I stick within my financial class and stay with the VW. Thanks for your help!
If you're comfortable working on the VW Passat, you should not have any problem working on an Audi. But Audis are a higher maintanence vehicle, especially the 2.7T motor, but you already know this.
So if you are willing to spend more money/time on maintanence and get a more responsive ride, then make the move up to Audi.
As much as people like to think the passats are very close to the A6, they are not. I found this out at my work, getting out of my A6 and into a 4 motion 2002 2.8 passat. Identical underneath, suspension, engine, tranny, exhaust... But, the driving position is completly different. The Audis dash is much higher, you dont sit as upright. You will have the same front suspension problems as they are the same parts. If you get a 2.8 or a 4.2, the maintanence will be about the same as your vw, probably easier with the 2.8, more room under the hood. The 3.0 is basically the same as the 2.8, just more expensive parts. The 2.7 has all the problems with turbos. Im 18, and I can afford my 2.8, even with all the suspension b.s. and the "AUDI" badge. You can still get most of your parts at your local vw dealer, and save some cash.
