A Quick Seafoam Question
Old Aug 7, 2008 | 01:09 AM
michaelh305's Avatar
Default A Quick Seafoam Question
What vacuum line do I use on my A6 2.7T to put in the Seafoam? where i it located? Thanks in advance
Old Aug 7, 2008 | 02:42 AM
oc_audica's Avatar
for the 2.8 we use the FPR Vac line
see pic (water/seafoam)
Old Aug 8, 2008 | 01:04 PM
nemohm's Avatar
Introducing Seafoam through vacuum line will fall short of cleaning the injectors.
Old Aug 9, 2008 | 02:48 PM
kimi's Avatar
this is new to me, will like to try using this compound but not sure what vacuum line to use, the picture above is not helping very much. i cant understand what water has got to do with it.
Old Aug 9, 2008 | 05:06 PM
oc_audica's Avatar
water will clean it like seafoam its just a little safer
and point taken about missing the injectors... what line are you guys using?
Old Aug 9, 2008 | 06:09 PM
hxgaser's Avatar
You can clean the intake with either water or seafoam. I did seafoam myself and worked great. Be sure to do it where it is well ventilated though. You will smoke the entire neighbohood and it is normal.
Old Aug 9, 2008 | 07:12 PM
kimi's Avatar
sorry guys, still cant concieve the idea of water in the intake, what vacuum line do you use anyway and what amount of water? by theway will this not wet the plugs or am i missing something?
Old Aug 9, 2008 | 07:45 PM
kimi's Avatar
when you add seafoam to your oil, do you have to drain it? do you have to change the oil at regular interval as usual?
Old Aug 10, 2008 | 04:06 AM
oc_audica's Avatar
you shouldn't run seafoam in the crank case longer than a fill up of gas
Old Aug 10, 2008 | 11:11 PM
hxgaser's Avatar
The reason that I did seafoam instead of water for my intake was that I was scared of using water. I have heard of many people doing it, but for some reason, water in my cylinder head didn't seem right. The reason that there is a t-fitting is that you can suck up seafoam and air at the same time. It keeps the idle high enough and keeps the car from flooding. Just run about a cup full, and it should be okay.
As for the crankcase, I ran it for about 200 miles and changed oil. Seafoam works be thinning oil and loosening old stuff. So it shouldn't be run for a long time.
ppgoal
Nov 11, 2009 01:42 PM
flynnr
Apr 9, 2009 02:55 AM
AAudiA6
Sep 5, 2008 05:58 PM
AAudiA6
Sep 5, 2008 12:05 PM
EOD5
Apr 6, 2008 11:17 PM
