Seafoam question on 3.0L
Old Sep 5, 2008 | 12:03 PM
AAudiA6's Avatar
Default Seafoam question on 3.0L
Hey Guys
I want to do a Seafoam on my 2002 A6 3.0, but I'm not sure where the Vac Line is located?
So I have 2 questions.
1. I'm not sure which is the FPR Vac Line on a 3.0L engine?
2. Will I have to change the Spark Plugs after the Seafoam treatment,
since apparently they get wet?
Thanks!
Old Sep 5, 2008 | 12:17 PM
auditech79's Avatar
You can use the fuel pressure regulator vacuum line, it should be on the fuel rail.
You should change the spark plugs after doing the seafoam treatment because they can easilly get fouled up. Just make sure to not pry up on the coilpacks to get them out, the 3.0L coils tend to break and cause misfires when prying on them.
Old Sep 5, 2008 | 01:36 PM
oc_audica's Avatar
I thought it was best to use one of the intake lines?
*I was however never able to find any images to help
Old Sep 5, 2008 | 01:43 PM
auditech79's Avatar
The FPR vac line is direct manifold vacuum. There isn't a whole lot of places you can inject seafoam on the 3.0L
Old Sep 5, 2008 | 01:53 PM
oc_audica's Avatar
*This also applies to the 2.8 30v right?
Old Sep 5, 2008 | 02:06 PM
auditech79's Avatar
No the 2.8L has all kinds of vacuum lines to tap into.
Old Sep 5, 2008 | 04:07 PM
whitey's Avatar
You wouldn't happen to have any pictures pertaining to the 2.8 would you? I just purchased my A6 and already put a can in the fuel tank but would like to run some through the intake and oil as well.
Thanks.
Old Sep 5, 2008 | 04:57 PM
nemohm's Avatar
I'd try WD-40 from the tank => cheaper and more effective (injectors) purge.
Or one could use Lubro Moly
or
just make yourself a blend from:
mineral spirits
naphtha
kerosine
(everything from WM)
for the fraction of the cost.
Good luck!
Old Sep 5, 2008 | 05:58 PM
auditech79's Avatar
Thanks.
No, i don't have access to the factory repair manuals anymore, but it can't be that hard to find. Just take off the rear engine cover, (where the rings are) there are tons of vacuum lines back there as well as the FPR vacuum line which is the ideal one to use as it goes into the manifold directly after the throttle body.
ppgoal
Nov 11, 2009 01:42 PM
timmay074
Aug 18, 2009 01:22 PM
jaymson
Aug 18, 2009 01:12 PM
juice88
Jun 26, 2006 08:39 PM
JohnnyBravoA4
Jun 13, 2006 04:46 PM
