A Quick Seafoam Question
You can clean the intake with either water or seafoam. I did seafoam myself and worked great. Be sure to do it where it is well ventilated though. You will smoke the entire neighbohood and it is normal.
The reason that I did seafoam instead of water for my intake was that I was scared of using water. I have heard of many people doing it, but for some reason, water in my cylinder head didn't seem right. The reason that there is a t-fitting is that you can suck up seafoam and air at the same time. It keeps the idle high enough and keeps the car from flooding. Just run about a cup full, and it should be okay.
As for the crankcase, I ran it for about 200 miles and changed oil. Seafoam works be thinning oil and loosening old stuff. So it shouldn't be run for a long time.
