Radio Problem
Old Feb 25, 2010 | 10:44 PM
harperman89's Avatar
Arrow Radio Problem
Hey everyone new Audi owner here with a 2000 A6 2.7t. I was working on the car tonight and I noticed that my radio wont turn on. I tried pressing a bunch of buttons but it doesn't turn on at all, nothing is displayed on the screen. I replaced the battery just the other day, so I figured it was that, but as I read through the forum I noticed that most people get a "SAFE" message pop up, I don't get anything. The heat controls right below the radio all light up and work. Oh and I also checked all of my fuses. I'm stumped, any help is appreciated.
Old Feb 26, 2010 | 01:23 PM
NH_USA's Avatar
What were you doing to the car? Did the radio ever work?
Recheck the fuses.
Other wise you'll have to pull the radio and see if there is power to the connector. You'll need to get Bentley with a wiring diagram to determine which contacts nee to be powered.
Old Feb 26, 2010 | 02:05 PM
ppgoal's Avatar
It's too cold to go outside and check my car, but make sure you have a working fuse. Fuses are on the end of the dashboard, driver's side and there should be a schematic on the panel. You have to open the door to get at them. Otherwise, pressing the left/volume control **** should turn on the radio. If fuse is good, then as recommended above check for power to the radio.
Old Feb 26, 2010 | 03:04 PM
I already checked the fuse on the driver side door, i checked all of them actually and they are all good. The radio worked fine a few days ago, I'm just not sure exactly when it stopped working all of a sudden. My guess is when i was working on replacing the battery but I'm not sure. I'll pull out the radio and look around there though, thanks guys. Also, I do have a Bentley manual so I'll be using that as a reference.
Old Feb 27, 2010 | 02:49 PM
In case anyone was wondering or has the same problem, I managed to fix it. The fuse in the back of the radio was blown. Replaced it and everything works, didn't even go into safe mode!
hlmorbit
Sep 29, 2012 08:25 AM
ffmist@hotmail.com
Aug 22, 2010 09:57 PM
amiddle104
Jul 21, 2010 04:14 PM
jan.hoj
Jan 10, 2008 07:31 AM
khaoswing
Mar 6, 2007 11:31 AM
