Rapid Turn Signal-like Sound New Member
Old Apr 15, 2007 | 07:24 AM
kgreen's Avatar
Default Rapid Turn Signal-like Sound New Member
Hi All,
I'm a new member - just bought an '02 2.7T and I'm getting an intermittent sound from the dash, behind the radio. It is the exact same clicking sound you hear when you have your turn signal on, but it happens intermittently without the signals on and it's a much faster frequency. If I'm hearing the noise and I turn on the hazards or the turn signals, the signal or hazard sound takes over from the fast sound, then when the signals are turned of the rapid sound continues.
What do you think?
Thanks
Old Apr 15, 2007 | 02:59 PM
Jeffla's Avatar
Default RE: Rapid Turn Signal-like Sound New Member
Just a guess, but I have read posts about the hazard relays going bad. I am not sure what the symptoms are, but maybe thats your problem. The relay is activating for no reason.
Just a guess.
Jeff
Old Apr 15, 2007 | 05:15 PM
daroshi's Avatar
Sounds like the signal/hazard light switch & relay (all part of the hazard light switch on the A6). I've replaced mine for the same problem. You can get one from http://www2.discountgermanparts.com/...h&dp=falsefor $32.95. It's very common and an easy fix...
Old Apr 15, 2007 | 05:20 PM
techbod's Avatar
^totally agree so change the switch
Old Apr 16, 2007 | 03:36 AM
kgreen's Avatar
Thanks for the help guys.
gmkane
Jun 9, 2013 05:45 PM
DjDiddles
Jan 16, 2009 01:51 PM
pa4ul
Jan 21, 2008 03:20 PM
Sabrenna
Mar 30, 2006 08:09 PM
paliracer
Feb 21, 2005 03:15 PM
