Sponsored by:
Sponsored by:
RE: tips and suggestions for the new 2.7t owner
Old 11-15-2007, 04:35 PM
Teutonic2.7T's Avatar
Default RE: tips and suggestions for the new 2.7t owner
I just put a deposit down on my new 2.7T.... pics soon…. The thread mentioned above has been invaluable. My A6 has 88K… instead of negotiating the price I managed the dealer to take it to an audi authorized shop to replace the timing belt and all assoc. parts, serp belt and water pump… also, replacing the breaks and an oil change.
I am now thinking of going a head and changing the o2 sensors and the Turbos. Changing the turbos are going to kill me. The dealer say’s that neither need to be changed… but I want to be proactive and hedge myself from any future damages.
What are the cons of not changing the turbos at 88K?
How can I tell that they are going?
What is a reasonable price for them to get fixed?
Also the temp sender should be green what does that mean? My mechanic doesn’t know what I am talking about?
What would you do?
Cheers all!
Old 11-15-2007, 06:53 PM
Four Ring Circus's Avatar
SoCal Crew Member
Don't mess with the turbos. They could last another 88K miles. Why replace them unless there is something wrong with them? They are expensive to replace and install. Good move with the timing belt service.
Old 11-15-2007, 09:25 PM
formulagigi's Avatar
great deal on the service they did but why would you change the turbos if they are ok.!?
Consider the following
- Upgrade the DV's
- Upgrade the TBB
- Get Piggy Pipes which will reduce the temperature behind the turbos therefore expanding their life. You'll gain reliability and probbaly 15hp/20lbs Tq if chipped.
- Get NewSouth Powergaskets... especially if you are going to change your auxiliary water pump (it WILL break and leak if not replaced already), this way no extra labor for the gaskets as they have to remove the intake to get to the pump. Otherwise, it is probably 2 hrs labor+ . The gaskets will lower temperature and add power.
ALWAYS ALWAYS warm your car up before pushing it, and not by letting it sit running in the driveway but by driving it easy.. and ALWAYS let i cool off before turning it off after spirited driving...
Old 11-16-2007, 01:47 AM
SoCal Crew Member
Just a question about piggy pipes. It basically guts your cats, making the car illegal for smog (at least in CA). Have any owners of piggy pipes run into this problem?
Old 11-16-2007, 11:59 AM
thanks alot for your responses... what about changing the o2 sensors? should i just go ahead and get them done?
Old 11-16-2007, 02:01 PM
just wait til they go...
4 ring circus...
piggies also relocate the 02 bungs pass the precat therefore no CELL and pass inspection
Old 11-16-2007, 04:20 PM
SoCal Crew Member
Thanks Formulagigi. I have these on my short list of desiredadd-ons since they seem to add life to the turbos in addition to a little bit of power.
Old 11-17-2007, 02:19 PM
you'll enjoy them
twinturbomew
11-19-2018 09:27 AM
everfresh
07-25-2010 10:27 AM
Mt07b7a4
12-28-2008 08:14 PM
jdoubleoe703
06-19-2007 08:57 PM
boysnightout
02-09-2006 11:26 AM
Quick Reply: RE: tips and suggestions for the new 2.7t owner
