Real main seal replacement
Old Sep 23, 2008 | 03:00 PM
soundguy's Avatar
Default Real main seal replacement
98 2.8q
I am preparing to replace the timing belt assembly.
The car has been leaking oil for a long time now, and I figured since I was in there I may as well fix the leak.
The audi dealer replaced the belt the first time apporox 2 years ago, and also the cam seals I believe. That did not fix the leak. It is not obvious where the leak is coming from.
So, looking through the bentley manual, I think the leak is coming from the rear main seal.
The manual states that the transmission must be removed in order to replace the seal.
The manual does not have a section on removing an automatic transmission.
It does, however have a section on removing a manual transmission.
Is the process the same for both automatic and manual?
Thanks.
nigel horne
Dec 3, 2020 12:11 PM
kprc51
Jul 21, 2009 01:26 PM
virtualelvis
Jul 20, 2009 10:56 PM
Sirn
Jul 23, 2008 12:53 PM
drewmellon
Jun 14, 2008 02:20 PM
