Rear passenger vent water
Old Jul 29, 2012 | 02:00 PM
mrchris42's Avatar
Default Rear passenger vent water
I have a B5 which has a soaked rear floorboard. We have had no rain for about a month and during a long drive across the hot sandy part of the state, there was standing water in the back after vacuuming it out a day before.
I did check the battery/windscreen drain which is clear and totally dry, and the sunroof drains just to be sure, which are also clear. I pulled up the carpet from the passenger front side and found the "funnel" and rubber grommet where the A/C condensate drains through the body and was able to pour water through it and onto the ground, So I know that's not clogged either. With the carpet pulled up and driving it, I see no water coming from the front drain, or from the front air ducts. I stuck a rag in the rear air ducts and they are soaked during every drive. What should I take apart next to find the A/C clog??
zpru127
May 2, 2013 10:53 AM
FonzoB5S4
Jan 8, 2011 08:26 PM
madridlover
Apr 10, 2008 04:10 PM
arianman
Mar 24, 2008 10:23 AM
hiwords
Nov 26, 2007 04:34 PM
