Rear window safety switch won't turn off
Old Nov 27, 2011 | 12:09 AM
OGBULLYLOCDAWG's Avatar
Originally Posted by Herr Avant
So I'm taxing my tiny brain here. Trying to release the drivers side window panel. Found an access hole and am trying to pry with a screwdriver to release plastic tab inside. No go. What am I doing wrong?
Originally Posted by hxgaser
Bend the tap and push up at the same time.
^photo assist
Old Nov 27, 2011 | 07:25 AM
westhive4life's Avatar
Is it possible to pull the switch out without removing the door panel? Because I have the same problem and I was going to just use something to keep the button down but if it's an easy fix I'll do it
Old Nov 27, 2011 | 01:06 PM
yeah, there's no need to take off the entire door panel.
Look under where the switches rest and you'll see the little hole you push it up from (with a screwdriver or whatever you can fit thru).
Old Nov 29, 2011 | 10:06 PM
Sweet. I'll just change mine then. Thanks
S8Dreams
Sep 23, 2015 03:48 AM
djreynolds
B7 Models
Aug 5, 2015 08:56 AM
Staudi911
Dec 6, 2011 04:20 PM
JamesandanA6
Jun 5, 2011 01:53 AM
tahoehtp
Jul 20, 2008 05:37 PM
