Remote Starter possible for A6???
Old Nov 21, 2005 | 04:27 PM
fiddle321's Avatar
Default RE: Remote Starter possible for A6???
Dankhound,
I called around to many remote starter installers, as you suggested. I found only one who has actually installed a remote starter into a 2006 A6. I asked them about how they deal with the immobilizer. They said they "don't bypass it," but rather, "interface with it." They focus on high end cars and said it would cost $450 to install. (Based on what I've seen in other message boards, the installer I called seems to be held in high regard.) I do not understand what "interfacing" with the immobilizer means, and have little knowledge about how this works. Perhaps you understand what he said?
Thank you.
Old Nov 21, 2005 | 06:50 PM
T90's Avatar
T90
Thye will be using a module that fools the car into thinking that there is a key in or near the ignition, thats what they mean by integrating or interfacing. You need to do this on any car that is equipped with a passive immobilizer. $480 sounds in the right range, and what type of unit will they be installing?
Old Nov 21, 2005 | 07:40 PM
fiddle321's Avatar
I believe it is called "Crimestopper." Is that good?
Old Nov 21, 2005 | 11:01 PM
T90's Avatar
T90
[>:]I am not sure, I have never heard of Crimestopper, see if they are able to get a compustar in
Old Nov 22, 2005 | 02:58 AM
dankhound's Avatar
That sounds like the shop id go with. All they mean by interface is set up a secondary input to the immobilizer so the key doesnt need to be in the car for the remote start to operated, however the system still remains operational. So a theif would still need to find a way to bypass the immobilizer to borrow your car. Usually the engine cuts out after 10 min if the key is not inserted.
Old Dec 1, 2011 | 09:01 PM
id04265's Avatar
Default $1200.00 with modified ignition module
I have a 2005 A6 and a Compustar I wish to have installed (from a prior car) My local installation outfit told me it would cost $1200 to put in my Compustar because 05 and 06 are the worst Audi's to install and it will require a modified ignition switch... ????
anyone believe this?
Old Apr 15, 2014 | 01:10 AM
abner_hagelsieb's Avatar
it can be done, its not rocket since, it just a car with CAN protocol... i have done it in 40 minute to my Audi a6 C6, i have made a video, heres the link:
massaudiowner
B8 Models
Apr 21, 2022 01:49 PM
guest196826
Dec 13, 2011 04:39 PM
lumend13
Aug 8, 2008 09:15 PM
Teutonic2.7T
Dec 31, 2007 10:55 AM
tmgolfx360
Sep 7, 2007 12:10 AM
