Sponsored by:
Sponsored by:
replacing air filter
Old 05-03-2006, 04:30 PM
onlysunny68's Avatar
Default replacing air filter
How easy is it replacing the air filter on a '01 A6 2.7T ? I read somewhere that one has to be careful with the MAF sensor.
Old 05-07-2006, 12:27 AM
dankhound's Avatar
Default RE: replacing air filter
The mass airflow is in the area but i cant think of any special precautions. The hardest part will be clipping in the airbox once you get the new filter in.
Old 05-07-2006, 02:59 PM
cnelson81's Avatar
yes, the clips are a pain in the ***... other than that its pretty easy. make sure to get a K&N
Old 05-08-2006, 01:44 AM
dankhound's Avatar
Dont waste your money on the k and n. The performance gains are negligable and there is the possiblity of coating the maf in oil resulting in incorrect readings. K and n can also distort airflow across the maf causing false readings.
Old 05-08-2006, 02:18 AM
cnelson81's Avatar
i recommended the k&n because it has a million mile warrantee for one. and it is rechargeable for another, meaning when it gets dirty, you can wash it out. I didn't recommend it for performance gains. If someone is trying to use an air filter for performance, they need to do a lil' more than that.
how can it distort readings?
Old 05-13-2006, 01:31 PM
dankhound's Avatar
It distorts airflow across the mass airflow meter. It also gets oil on the sensor.
Old 05-13-2006, 02:04 PM
totally agree the oil from the filter contaminates the MAF sensor, you can get dry K&N panel filters
harryd14
B7 Models
16
08-18-2008 07:53 PM
alan93
12-12-2007 05:57 PM
HorchA3
11-18-2007 10:26 PM
twinblowersonice
11-09-2006 05:47 AM
FezA4
08-06-2004 04:14 PM
Quick Reply: replacing air filter
