Sponsored by:
Sponsored by:
Reseting indicator at center of guage console
Old 05-05-2009, 09:43 PM
verEYEzon's Avatar
Default Reseting indicator at center of guage console
My brake worn light and Rear Brake Light indicators are going off. I have the breaks to swap out and I have swapped out the burnt brake light.
How can I reset it so that it no longer shows the the brake light needs replacing?
Old 05-05-2009, 10:32 PM
nm3210's Avatar
well it should go away when you replace the pads, did you make sure to get the brake pads with a sensor in them and make sure to hook up the sensor?
https://www.audiforums.com/forum/sho....php?p=1060908
Old 05-05-2009, 11:21 PM
verEYEzon's Avatar
No, I have not installed the front bads to zero out the warn pad indicator.
I have replaced the burnt out brake light, however, the "Brake Light" indicator still flashes.
(Yes, I've made sure all tail lights are working and that it's not indicating another bulb is burnt out)
Old 05-06-2009, 12:09 PM
NH_USA's Avatar
is it brake light or low fluid?
did you use the correct bulb?
Old 05-06-2009, 03:48 PM
verEYEzon's Avatar
Brake light as it says "Brake Light"
As for the bulb...I see this as a loaded question, but I'll bite.
The bulb I replaced it with has the dual contacts at the base and fixed my problem of not having a right side brake light.
Old 05-07-2009, 09:56 AM
NH_USA's Avatar
I believe the light out sensor measures resistance. The wrong bulb might activate it or you might have more than one light out.
Alexa01a4QS
03-16-2009 11:10 AM
roofboy2
08-09-2008 09:18 PM
seattlea6
08-06-2007 02:41 PM
shockedimpy
01-25-2007 07:01 PM
mrdb85
10-17-2006 01:22 PM
Quick Reply: Reseting indicator at center of guage console
