Ribbed belt ?
Old Dec 27, 2007 | 11:15 PM
cr!mz's Avatar
Default Ribbed belt ?
Hi guys. I have question... I bought my 00 2.7T about 2 weeks ago and It has ~128 000 km. In my maintenance booklet it says that the "Ribbed belt" should be replaced at 120 000 km. I have some weird sound and I was thinking to replace my timing belt. Also, a weird thing happened to me. A week ago I was stuck in parking lot with about 10-15 cm snow, so i pushed it a bit to get out of there and some smoke came in. With a hard smell... (can't specify it)... I thought it was clutch but its not.. anyways :P I was wondering if these 2 things can be from this ribbed belt. Can someone tell me what exactly is this ? I found this: http://parts.autopartsonlinecanada.c...Multi+Rib+Belt
but not sure...
Every input is appreciated.
Thanks in advance..
*PS: I had 17521 (P1113) Bank1-Sensor1 Internal Resistance too High code on vag-com today, which I believe is O2 sensor.... If anyone can relate this to the smoke effects I got... :P
Thanks again
Old Dec 28, 2007 | 11:39 PM
cr!mz's Avatar
Default RE: Ribbed belt ?
Bump[&:]
Old Dec 29, 2007 | 02:51 AM
frankinstyn's Avatar
Sounds more like the all-too-common oil leak than the belt. The oil leaks onto the exhaust manifold and causes a smell. As for the smoke...what color? If that smoke was caused by the same leak then you need to fix it quick (don't worry no damage done in this case).
If it was the belt then there is a major problem such as the water pump siezed or the idle pully siezed. Both are easy to check. Look for abnormal wear on the belt. Should be fairly obvious.
Were there any other symptoms? Temperature, clatter, squeal...
Old Dec 29, 2007 | 01:13 PM
cr!mz's Avatar
There's this belt that you can see when pop up the hood and it has a line on it... seems like it must be changed. I believe it's not the timing belt... I wonder if thats the "ribbed belt".. :P
Old Dec 29, 2007 | 01:21 PM
techbod's Avatar
ribbed belt is the fan belt as some call it but its called a serpentine belt that drives all the main things, the timing belt is behind it
Old Dec 30, 2007 | 09:34 AM
ppgoal's Avatar
You're at about 78k miles and that's closing in on timing belt, water pump, etc change as well. Normally the serpentine belt gets replaced at the same time. Just something to keep in mind. If you read discussions on the forum you'll see recommendations from 75k and up. FYI, I did mine at 94k.
Old Dec 30, 2007 | 12:21 PM
cr!mz's Avatar
In the maintenance bookleet:
Ribbed belt: 120 000 km
Timing belt: 156 000 km
I'm at 128 000 now
Old Jan 2, 2008 | 07:35 PM
hxgaser's Avatar
ORIGINAL: cr!mz
I'm at 128 000 now
Yes it is what the maintenance book says, but also check the under side of the hood for the change interval. My book says around 100K miles for the timing belt, but the sticker under the hood actually says 75K miles. I heard it on places that the reason that they list higher mileage number is to make the ownership cost seem low in the book, but in reality, it is really recommended to to the timing belt around 75 to 80K miles. I personally would not risk it if I am planning to keep the car forsome time.
susyhun
Feb 4, 2013 05:22 AM
rradovitch
Sep 2, 2009 07:39 PM
Dana Reed
May 26, 2008 04:47 PM
shaf
Jan 9, 2008 04:02 PM
2.7 T
Jan 7, 2008 01:22 PM
