right headlight dimmer than the left
Old Aug 13, 2010 | 02:11 PM
a6forever's Avatar
Cool right headlight dimmer than the left
1999 a6Q (4b model, AHA engine, certified to 100k - now has 159k) had for 10 yrs & have fixed some of my electrical issues using posts on this site - all work on my car has been done by me. i just replaced my cloudy headlights with angel eyes from ebay. however, when looking at the lights the right side is dimmer than the left. so, i put a volt meter on both wiring harnesses ( driver & passenger side ) to rule out the new headlights & i am receiving 12.2v on the driver side & 11.4v on the passenger side. can someone explain what relay or connector i should be looking at for a shorted connection or post a6 wiring diagram.
Old Aug 13, 2010 | 06:06 PM
Jackmup's Avatar
If they are HID you should check the Ballast and wiring to the light from the ballast. Be careful, HIGH OUTPUT.
Old Aug 17, 2010 | 03:37 PM
a6forever's Avatar
Default headlight issues!
thanks for responding. headlights are halogen. i am trying to trace back from the headlight where the passenger headlight wiring harness connects. i believe if i can find that i may be able to find a connector pin that is being grounded, melted, or just not getting a connection. i removed the glovebox & have not found the passenger wiring harness. any help would be appreciated.
Also, i recently replaced the headlight switch to see if it was the issue, but no change. i only ruled out the switch that turns the lights on.
Old Aug 17, 2010 | 04:32 PM
NH_USA's Avatar
Time for you to get the Bently manual for your car and begin tracing wires. It is probably the ground on the right side!
Old Aug 17, 2010 | 05:55 PM
a6forever's Avatar
i should have the techni book cds any day now i won from ebay. just trying to get this out of the way in free time today so just looking for a direction as to what number the connector plugs into on the lower right pillar.
i agree it is probably a ground touching something or melted to plastic & not getting full voltage.
95AWDdsm
Aug 26, 2013 05:52 PM
95AWDdsm
Aug 25, 2013 10:12 PM
Audi A8L Ithaca
Aug 4, 2012 04:15 PM
aznavurian
Jul 29, 2007 02:18 AM
hyrumbradshaw
Oct 18, 2006 05:24 PM
