Right side steering arm issue
Old Aug 27, 2013 | 11:46 AM
fergusfourrings's Avatar
Default Right side steering arm issue
Hi, I just rotated the tires on my 99 A6 with 109K. I noticed the right steering arm moves about an 1/2 inch from side to side. All the ball joints look to be ok. There are no leeks, wobbles, clunks, or anything else wrong. Is the rack going south?
Old Aug 27, 2013 | 04:12 PM
CRuby's Avatar
Side to side meaning in the direction of the tierod? Could be steering tierod end wear. Some info on tierod ends here:
Audi Tie Rod - Audi Tie Rods Low Price Leader
Old Aug 27, 2013 | 05:48 PM
Yes, tie rod side to side. after looking at the link you posted, it must be the inner tie rod end, the outer end looks good.
Thanks
Old Aug 28, 2013 | 09:40 AM
CRuby's Avatar
Just did our tierod ends (TRE), along with control arms. Per the link I sent, you can see the OEM outer TRE design has a bolt head imbedded in rubber. The rubber can deteriorate over the years and it's possible this joint can get play in it. I expect it's more coomon for the outer TRE to go bad, particularly the ball joint, since it's not shielded by the track arm boot, & of course the ball joint gets exercised more. Possible you can hold the track end & see if play is localized to the TRE. Be sure to soak the TRE threads to the inner tierod with PB blaster. These are known to seize up & are a PITA to remove sometimes. On ours, ones side unscrewed easily, while the other didn't. I had to resort to using long arm pipe wrenches & jury rigging to hold inner & turn outer. Be sure to count # of turns to remove to get alignment close to before.
Old Aug 28, 2013 | 12:54 PM
I'll do that,thanks
Tomoko
Mar 28, 2015 07:18 PM
lawnmore
Jan 29, 2015 07:39 PM
tculber
Jan 24, 2008 09:12 AM
2005r6
Aug 9, 2007 10:15 AM
Diavan
Jul 6, 2005 03:24 AM
