rim size
Old Nov 30, 2006 | 12:41 PM
bloodshot's Avatar
Default rim size
what is the stock rim specs for '96 a6 2.8 quattro?
I believe it was 15" rims. Can I go like 17 or 18? and how wide can I go if I do that?
Old Nov 30, 2006 | 04:01 PM
beefski's Avatar
Default RE: rim size
Yes 15" is correct. You can go to 16" and not have the speedo be incorrect.
Try tirerack.com the site will show all rim sizes that will fit.
Old Nov 30, 2006 | 04:49 PM
Boston_A6's Avatar
use this link:
http://www.miata.net/garage/tirecalc.html
it will tell you the speedometer effect from different wheel/tire size combo's
most people will tell you to stay within 3% (total size wheel+tire) of the original spec.
Old Nov 30, 2006 | 06:28 PM
AQ6's Avatar
AQ6
I had BBS RX rims 17x8 +35mm offset with 225/45 17's on a 99 A6 Avant. Recommended size is 205/55 16. The difference between the two was minimal. I wouldn't recommend going much bigger.
Old Nov 30, 2006 | 11:18 PM
Audi A6 4.2's Avatar
Default Rim size
Hey I have a question for who can help me. I have a 2000 A6 4.2 will the 16in rims off a regular A6 fit my car due to the offset if the wheel? Thanks
Hecareth
Oct 14, 2009 10:59 AM
mystrodo
Sep 2, 2009 09:41 AM
flajoecool
Oct 24, 2007 07:02 PM
invincible569
Nov 18, 2005 02:43 AM
