Rubberized Interior Paint
Old Jul 27, 2007 | 10:49 AM
Costner's Avatar
Default Rubberized Interior Paint
Does anyone know of a source or supplier for the rubberized paint that coats everything on our interiors? The buttons on my climate controls (- and +) and part of the stock Bose Symphony Headunit are scratched off and I'd like to retouch them, but anything other than the stock rubberized paint is going to look horrid.
On the door panels I actually took them apart and used a scotchbrite pad to just remove the coating and that looks good - but on the headunit and climate controls that wouldn't work as the buttons would be all white and the black appears to be more glossy underneath.
My local autobody shop had no clue so I'm hoping somebody has some more info.
Old Jul 27, 2007 | 10:58 AM
techbod's Avatar
Default RE: Rubberized Interior Paint
its a clear coating used as a primer on plastic parts that's the problem, when its cleaned off and and primed with the proper stuff which is flexible then you can paint it ( most people just paint the plastic with interior paint for plastic and don't use the clear coat primer ) and thats when it goes bad
Old Jul 31, 2007 | 03:00 PM
railrunner's Avatar
I know many, including me with same issue, particularly on light switch. Keep us informed on what you find out.
Old Jul 31, 2007 | 03:08 PM
Costner's Avatar
Yea I haven't found anything with the same smooth feel as the stock paint. There are good plastic paints out now that will stick just fine and won't just peel off right away, but the texture and look is different, so it would be impossible to blend.
If I find anything I'll let you know, but so far no such luck. I can't beleive Audi or VW doesn't stock this stuff in a rattle can!
Old Jul 31, 2007 | 03:19 PM
railrunner's Avatar
have you written audi usa?
Old Jul 31, 2007 | 04:44 PM
teranenrique's Avatar
I would also want to know, my radio is doing such thing around the volume ****
GoremanX
Aug 31, 2012 12:52 PM
Phat_J
Aug 21, 2010 03:48 AM
thepirate
Jun 26, 2007 12:09 AM
aRIf
Dec 10, 2006 01:31 PM
patmine23
Jul 13, 2006 12:29 PM
