Secondary Air Injection System
Old Nov 4, 2009 | 08:41 AM
WoodShoe's Avatar
Thumbs down Secondary Air Injection System
Just got 2 codes this morning for my SAIS. Low flow for bank 1 and 2. Havent looked under the hood yet to check things out but Im wondering if there is a relay for the pump somewhere or a fuse that I should check first. I have doubts that its carbon build up since both the banks threw codes at the same time.
Old Nov 5, 2009 | 08:30 AM
bob martin's Avatar
It's probably the pump itself as they are a known problem. Search the forums for replacement instructions and elimination options.
Good luck!
Bob
Old Nov 5, 2009 | 11:34 AM
hxgaser's Avatar
I would check for vacuum leak first.
Old Nov 5, 2009 | 04:27 PM
NH_USA's Avatar
73.8% of the time a secondary air injection code is due to bad vacuum lines, but if it throws codes for both sides the probability of a bad vacuum line drops to about 50% - The vacuum hoses are cheep so start there and then the fuse - only look at the pump after you've eliminated the cheep stuff.
Old Nov 5, 2009 | 07:40 PM
WoodShoe's Avatar
Ill start ripping it apart tomorrow. I tried to find fuse for it on the main panel but its not there. Must have a relay somewhere ...
Old Nov 6, 2009 | 07:20 AM
WoodShoe's Avatar
In my search for knowledge about this SAI I found this.
http://www.vaglinks.com/Docs/Audi/C5...aintenance.pdf
Its part of a bentley manual that shows everything you need to know about the SAI on the 4.2L.
corcorand
May 21, 2014 12:12 PM
Collision Bob
Mar 24, 2013 09:42 PM
Zack1661
Feb 4, 2012 12:48 PM
millenia
Dec 11, 2008 10:53 PM
Texas_A6_4.2
Jan 17, 2007 02:29 PM
