Seized Turbo - DIY Replacement
Well, how did you just remove the turbos with the engine in? I know you said you would rather pull it out if you did it again. But i think woudl rather spend 16 hours fighting it in and out as opposed to 40 hours to remove and replace the whole motor.
Pohsib, did you pull them from under the car or remove the bolts and extract them out the top?
Im pretty mechanically inclined and i have removed and replaced a motor in a honda prelude, so i feel capable. But i just have the impression that pulling the motor on my A6 might be more of a headache and easier to mess up.
I will soon be facing 'engine out' on my 2.7T C5s (A6 auto, Allroad auto, Allroad manual).
I read here "whole front comes off and pull engine forward" and "drop subframe/trans/engine".
a) which is easier? Consider hoist available
b) is first method a 'no hoist required' method (car on jacks)?
Links to good write ups?
AC lines: I was always able to 'swing' the entire assemblies to the passenger side (when doing timing belts). Not possible this way when taking engine out?
