symphony radio on my A6 how to imput code
Old Aug 25, 2007 | 04:00 PM
cgomezh2h's Avatar
Default symphony radio on my A6 how to imput code
does any of you knows how to input the radio code on my A6, my radio is the symphony two with casette and a cd changer on the trunk.
I requested the code from the dealer and I have it but my mechanic disconected the battery and the safe mode in in the radio.
please tell me which buttoms I have to push to be able to input the code.
thanks again.
Old Aug 25, 2007 | 04:01 PM
cgomezh2h's Avatar
Default RE: symphony radio on my A6 how to imput code
the audi a6 year is 2000
Old Aug 26, 2007 | 01:09 PM
A6Willy's Avatar
Turn ignition to on, not starting the car. You will see the word SAFE. Press both the RDS and FM2 buttons at the same time until you see a four digit number appear. Using the 1,2,3, and 4 buttons enter your code. 1 will change the first number, 2 the second and so on. Once you have the correctcode entered, press the RDS and FM2 buttons again, holding them until the radio comes on which should only take a few seconds.
Old Aug 27, 2007 | 01:58 AM
cgomezh2h's Avatar
thank you, but my car radio is a symphony. i find out how to do it.
TURN RADIO ON (SAFE) SHOULD APPEAR
HOLD P.SCAN AND RBDS BUTTONS IN SIMULTANEOUSLY TILL (1000) APPEARS
THEN USE 1THRU 4 PRESET BUTTONS TO ENTER 4-DIGIT SECURITY CODE. 1 BEING THE FIRST NUMBER IN SECURITY CODE.
WHEN ENTERED. THEN HOLD IN P.SCAN AND RBDS BUTTONS AGAIN TILL SAFE APPEARS THEN IT SHOULD BE UNLOCKED
Old Aug 27, 2007 | 07:35 AM
ldtikk's Avatar
Hi, how did you receive your code from the dealer? I asked them, they said they need to remove the radio,
looking serial number from the back and contact with Audi for the code.
I dont't understand why win number not enough for them. I need to replace my battery, I talked with my
mechanic, we need to replace the battery under power, from a charger to the cigar lighter.
Old Nov 11, 2008 | 09:35 PM
kwabena's Avatar
I used this and it worked for me. Thank you.
mtwebster
Dec 7, 2013 07:10 PM
kk1l
May 18, 2011 08:51 PM
joesta19
Apr 18, 2009 09:54 PM
Karwatma
Jun 1, 2008 07:17 PM
rsrbljan
Feb 12, 2008 04:50 PM
