Timing belt on a 01 4.2l, what is the real deal?
Old Jul 16, 2007 | 08:34 PM
ericgl's Avatar
Default Timing belt on a 01 4.2l, what is the real deal?
Last week I purchased a 01 A6 with ~87,000 miles. While interviewing for a shop, the people I talked with made me feel I needed to get the car in right away for service, Audi says 105K. Who's right?
Am I on borrowed time, or am I safe for a few thousand miles?
Old Jul 16, 2007 | 08:54 PM
twinturbomew's Avatar
Default RE: Timing belt on a 01 4.2l, what is the real deal?
audi changed there service from I believe 105k to 80k due to the number of timingbelt failures that were accuring before the sugested service mileage.
at 80k I would say that you are right for a timing belt service.
my suggestion to you is to change the waterpump along with all the tenchoners also make sure you are getting real oem replacement parts. there are cheap replacement parts out there that in some cases are no better than the already failing part you replaced
Old Jul 16, 2007 | 08:55 PM
auditech79's Avatar
The real deal is the factory does recommend replacing the timing belt at 105k yes, but many people across the U.S. have had snapped timing belts causing head damage or water pump failures at around 90k. So replacing the T belt, water pump, thermostat, and rollers&tensioners is almost a must at 80k.
Old Jul 16, 2007 | 09:28 PM
ericgl's Avatar
Thanks, the shops are full of flooded vehicles this week (Houston), so I'll get it in next. Hopefully it will be good for another 1k.
Old Jul 17, 2007 | 05:19 AM
Baskin 4.2l's Avatar
Actually the factory no longer suggests that you wait 105 miles the ACTUALL request from Audi is at 75k so the sooer the better
Old Jul 17, 2007 | 11:30 AM
cary12's Avatar
I had mine replaced along with the water pump and some other scheduled maintenance at $70k just to be safe. You should have it replaced sooner than later...
Cary
Old Jul 17, 2007 | 02:42 PM
Ice Train's Avatar
What's the normal price for this if it's just the timing belt versus with doing the water pump also?
Old Jul 17, 2007 | 08:14 PM
ericgl's Avatar
My 2 'Euro' shops quoted ~$1500 for the complete job. I believe the water pump and replacementis less than $200 of the total.
Old Jul 25, 2007 | 12:48 PM
ijrc's Avatar
1999 audi a4 1.8t quattro, i was just quoted $775 for timing belt alone at dealership
$1250 for timing belt and water pump from dealership
JayC707
B8 Models
Apr 15, 2012 06:48 PM
zuki'kid
Aug 3, 2010 11:59 PM
BarefootPanda
Dec 29, 2008 09:40 PM
kingman
Feb 10, 2008 04:41 PM
Belligerenceā„¢
Mar 5, 2007 10:47 PM
