Timing belt replacement--> burning oil smell --> noxious exhaust smell
Old Dec 27, 2008 | 10:38 PM
seanpawn's Avatar
Default Timing belt replacement--> burning oil smell --> noxious exhaust smell
gggggggggggggggggggggggggggggggggggggggggggggggggg ggggggggggggggggggggggggggg
Old Dec 28, 2008 | 01:55 AM
gmatov's Avatar
When it's warmed up enough to give you heat, lift the hood and check to see that the rubber gasket is in place across the rear of the engine compartment that the hood seals against. Check too to see that there are no kind of plugs/caps out of their holes in the firewall.
No fumes from the engine compartment should reach your heater air intake. There shouldn't BE any fumes from the engine, unless you have an exhaust leak or oil leak that is hitting a hot surface.
While you're there, look to see if you can find the source of the smoke. Hard to do with these cars, everything's shrouded in plastic.
Hey, if they wrote 1 year, you GOT 1 year. I'm sure you have had something break 1 day after the warranty expired, you are SOL. You're a month under, you got a month to go in which they are liable.
Cheers,
George
Old Jan 9, 2009 | 07:11 PM
seanpawn's Avatar
Old Jan 10, 2009 | 03:50 AM
chefro's Avatar
Thanks. Good thing you found the problem.
Old Feb 10, 2009 | 12:18 PM
TonyTone5390's Avatar
Originally Posted by seanpawn
Well if anyone's curious the problem was due to the "breather hose"
"Breather hose"? is that the PCV system?
Just trying to see if that's my problem as well.
Old Feb 10, 2009 | 01:26 PM
optimaPlus's Avatar
It sounds like you should get back to dealer who really did the job. I know it's hard to convince but the best way would be to show them an invoice describing job details and cause of the problem.
spikezone2004
May 5, 2012 12:01 PM
fourringking
Jan 13, 2012 03:16 PM
fourringking
Jan 12, 2012 04:03 PM
moeron7
Nov 8, 2010 01:32 AM
batoradaudt
Mar 5, 2008 11:30 PM
