Tire Pressure System Issues
Old Feb 12, 2010 | 11:11 AM
Tbrent2000's Avatar
Default Tire Pressure System Issues
My tire inflation system (86 - A6 3.2Q) is constantly warning of a malfunction. I've had the dealership check it out twice now, under warranty. And the first time they reported one of the tires was low, while the second time they attributed it to temperature changes. I've been checking the pressure often and have not observed any measurable changes. Since I am continually resetting the system and not losing pressure, I am convinced this is a sensor or other electronic problem.
Has anyone else experienced similar problems and, if so, how were they resolved?
Thanks.
Old Feb 12, 2010 | 11:14 AM
TwinTurboC5's Avatar
What year model is your car?
Old Feb 16, 2010 | 10:50 AM
Tbrent2000's Avatar
Default 2006
Sorry, It's a 2006
Old Feb 16, 2010 | 07:38 PM
Default Hi
Hi, Again
If your car is still under warranty I would take it back to the dealer again. If not...then consider where you live??? and the extremes of the cold temperatures there may be some validity in what the tech said about the tire pressures dropping with the cold weather and causing the light to come on. Are you running the car with OE tires and at the OE specified air pressure? There should be a label in one of the door jams specifying air pressure for the tires.
Old Feb 17, 2010 | 06:56 AM
Kevin's Avatar
Originally Posted by Tbrent2000
Sorry, It's a 2006
I have set up a TSB library for the C6. Take a look at the TPMS section in the library and you will see 4 or 5 TSBs dealing with the TPMS. Perhaps one of them will help.
http://www.uberlame.com/a6_tsb/Audi%...TSB%20List.htm
Old Feb 17, 2010 | 09:14 AM
NH_USA's Avatar
Problem #1 -You have to go to an Audi dealership because of warantee issues.
Problem #2 - see above
Problem #3 - see problem #1
There is no excuse -- Tell the dealer to fix the problem or you'll complain to Audi, National Transportation Safety Bureau, Better Business Bureau, and God. It should work correctly no matter what the temp is - don't let them be wishy washy --
PS I hate the tire pressure systems because of failed sensors and crap logic.
Old Feb 17, 2010 | 10:18 PM
Audi Tek's Avatar
Tech Certified
+1
Thats why Audi is going away from sensor..... and uses ABS sensor logic to calculate tire pressure.
Haven't had really any issues really. other than tires themselves....
Old Feb 18, 2010 | 12:51 PM
NH_USA's Avatar
How do they use ABS sensor logic to calculate tire pressure?
One would think that the rolling diameters could be different but that would require significant logic due to things like weight distrubution, etc.
TaylorA4
B7 Models
10
Jul 26, 2011 11:28 PM
drflaco216
B7 Models
May 24, 2009 07:04 PM
lysal
Feb 22, 2008 07:03 PM
RonD2000
Oct 22, 2007 04:06 PM
RonD2000
Oct 15, 2007 05:30 PM
