tranny failed because of fluid change?
Old May 30, 2008 | 06:50 PM
hxgaser's Avatar
Default RE: tranny failed because of fluid change?
ORIGINAL: madridlover
ORIGINAL: a6hcw
I used the blauparts kit to change the ATF on a 1998 A6 Quattro wagon. You may need more ATF than is in the kit, so order a little extra ATF. You need to follow the Audi shop manual from BentleyPublishers.com and use VAG-COM from www.ross-tech.com for checking the ATF temperature. Also, put the car securely on jack stands with all the driven wheels off the ground. The kit has an ATFhand pump for refilling thru the side transmission pan hole.
So putting the rear tires on ramps and the front of the car on jack stands won't work?
It will work as long as you bring up the jack to about the same level as the ramp.
Butternuts
Apr 5, 2008 07:13 PM
JaceTun
Mar 15, 2008 12:01 PM
sandman
Aug 5, 2007 01:26 PM
onepoint8tee
Jan 31, 2006 08:09 PM
