Trans oil line
Old Oct 22, 2008 | 12:28 PM
NH_USA's Avatar
Absolutly -- VAG Com tells you the tran oil temp --If I remember correctly it should not drip at 65C and it should drip at 70C -- AND the vehicle must be level AND you MUST use the correct fluid. I might be off on the temperatures but the 5C makes a difference - it was magic - one temp and everything is dry and 5 C later it drips. You'll have to search for the correct VAGCOM measuring block to see the trans temp. It is not obvious...
Almost forgot - don't open the plug with the motor off. - the oil just pours out.
ryal
B8 Models
Dec 14, 2013 05:42 PM
buyaudi
Jan 7, 2013 10:16 PM
07AudiA3
Jul 22, 2010 03:22 PM
cefurod
Apr 2, 2009 08:45 PM
mat.martins
May 15, 2006 04:01 PM
