Transmission Control Module replacement
Old Jan 6, 2010 | 09:55 AM
rl-1964's Avatar
Default Transmission Control Module replacement
2003 A6 3.0 CVT. Can anyone help with tips on removing and replacing the TCM module?
Thanks.
Old Jan 9, 2010 | 02:01 AM
rl-1964's Avatar
Default TCM replacement help!
Anyone? I would really like to get an idea if it's a reasonable DIY job! Thanks.
Old Jan 9, 2010 | 03:03 AM
Midniteoyl's Avatar
Could try an post instructions, but fairly involved if you havent done one before and dont know what your looking at.. and it needs to be re-encoded when done. CVT's are finicky and you should prolly let a shop do it...
Old Jan 9, 2010 | 08:02 AM
nothing77's Avatar
If it's in the same locatin as the 2.7t, then it is a 2 minute job
Old Jan 9, 2010 | 08:26 AM
bob martin's Avatar
The control module for the CVT is inside the transmission, but it looks like just remove a cover plate and there it is. Here is a picture (you might have to create an account to get access): http://www.vagcat.com/epc/cat/au/A6Q...64/51/3427078/
Good luck,
Bob
Old Jan 9, 2010 | 12:11 PM
rl-1964's Avatar
Thanks Bob, the vagcat picture does confirm that it's in the back of the transmission, although I thought, maybe hoping, that it was on the outside!
Jim, it looks like it's a matter of removing a real cover and then unbolting the unit...is this right? If so, can it be done on the car or does the transmission have to be removed?
I came across a BBA-reman website wher you can send the TCM in for repair, I was told about $500...has anyone heard of them?
http://www.bba-reman.com/content.asp...di-A4-2004-TCM
nothing77, it must be different to yours...I've seen discussions on shops quoting around $1400 to $4000 at the dealership so as much as I would like it to be...I can't imagine it's a 2 minute job! thanks.
The problem we have been having does seem to be intermittent, the flashing drive selector display has been mostly on, even though the car drives fine and sometimes it goes back to displaying the gear normally. In the begining we had an occasional problem where the car would not reverse after shifting into R, shift back into P, back to R and then it would be OK. I checked the connector at the back of the transmission and it seems to be clean without any corrosion. Another thing we've noticed is that you can move the gear selector into gear without having your foot on the brake pedal. Is it possible that something is interfering with the shifter below instead?
Hopefully the additional information might provide some insight for the experts out there?!
Thanks,
Rich
Old Jan 9, 2010 | 02:41 PM
Midniteoyl's Avatar
Sorry.. havent done one, but looking at the steps, while seeming simple, if you havent done it before, can be confusing... and, there are more steps than it looks.
Le-Pog0
Oct 4, 2016 01:17 PM
Le-Pog0
May 8, 2012 10:59 AM
rskinCA
Nov 23, 2008 05:24 PM
rskinCA
Oct 21, 2007 06:11 AM
