trouble pinpointing a coolant leak
Success!!! She's together and purring like a kitten...and no leaks. It was the spark plug cables. I had the po301 and po305 codes again. I swapped the cables on cylinder 5 and 3 and the code po303 came up. Sooo, O'Reilly's got me a set today, got them in, and she ran like a champ.
I think I did a whole lot of extra work for nothing.
But I do have some new experience and a better understanding of my car. So it is what it is.
The p/s sounded awful, but after driving it a bit sounds like it used to. That was weird. It sounded really bad.
I still haven't found where that connector goes. Is there a diagram of some sort that I can reference those connectors that are grouped together by the p/s reservoir? If I can at least figure out what part of the circuit it belongs to, I might can find where it goes. I have yet to find anything not working.
Thanks again for wall the help!!!!
But I do have some new experience and a better understanding of my car. So it is what it is. The p/s sounded awful, but after driving it a bit sounds like it used to. That was weird. It sounded really bad.
It's always something, lol.
I did my timing belt service, buttoned everything up -- within' the next 3 days, my alternator went out, I had a mysterious no start issue (no crank, just a click and it wasn't the battery -- fixed itself before I could figure out what the problem was), rear brake caliper seized, then a headlight issue after I adjusted them too far inwards causing it to pop off the adjustment *****, had to remove the headlights, open them up and fix that.. lol.
But as you touched on, the learning experience is a great, especially when your wrenching pays off in the end.
Congrats!
As for the question about which is better... OEM pink lasts longer, but the green stuff isn't bad.
Cioffie
May 19, 2013 10:24 PM
