Turn indicator issue
Old Mar 6, 2013 | 11:59 PM
A6C5's Avatar
Default Turn indicator issue
I have a 98 A6 Quattro auto trans with a right front turn indicator not functioning. Right rear turn indicator is functioning, but with a fast flash rate. Left side turn indicators are normal and operational. I replaced front right turn indicator bulb and it is still not operating. Could this be a relay that needs replacement? I was unable to remove stubborn headlight harness connector to check bulb contacts. Would a bad connection at turn indicator cause a rapid flash rate on the right indicator. I am thinking relay failure and replacement. TIA
Old Mar 7, 2013 | 05:26 AM
TwinTurboC5's Avatar
Have you checked the signal indicator that's mounted on the right front fender?
Old Mar 7, 2013 | 10:28 PM
A6C5's Avatar
Yes I have the right side fender mount signal indicator works and flashes at a fast rate just like the right rear signal indicator.
danstr1
Nov 24, 2011 07:34 PM
Gretch
Jun 4, 2011 01:42 PM
kobe24
Apr 16, 2009 12:20 PM
rawburt
May 9, 2008 06:07 PM
fischgrape
Jan 20, 2008 01:47 PM
