Turn Signal Blinks fast
Your bulb is fine. I've had the same problem on my car. The problem lies in the connection between the light bulb and the connector. Some times the metal contacts are spread to far apart which causes the signal to arc across making the blinker flash faster than normal. To fix this, pull out the bulb with holder and add some solder to the contact that looks burnt. Just a dab of solder is all you need and that should fix you right up.
I did this to mine about 1 1/2 years ago and haven't had the problem resurface.
Good Luck!!
Good Luck!!
