Turn Signal Blinks fast
Old Nov 13, 2006 | 12:48 PM
FixOrRepairDaily's Avatar
Default Turn Signal Blinks fast
The turn signal blinks fast, does this mean a bulb is out. Please advise.
Old Nov 13, 2006 | 12:57 PM
madridlover's Avatar
Default RE: Turn Signal Blinks fast
Your bulb is fine. I've had the same problem on my car. The problem lies in the connection between the light bulb and the connector. Some times the metal contacts are spread to far apart which causes the signal to arc across making the blinker flash faster than normal. To fix this, pull out the bulb with holder and add some solder to the contact that looks burnt. Just a dab of solder is all you need and that should fix you right up.
I did this to mine about 1 1/2 years ago and haven't had the problem resurface.
Good Luck!!
Old Nov 14, 2006 | 09:00 AM
Baskin 4.2l's Avatar
F O R D nice
check all the bulbs to make sure but mad is correct. The contacts can get spread or loose contact. try some solder or some electrical grease
TTsteve
Sep 27, 2020 05:55 PM
GDab
Aug 18, 2012 11:58 AM
muckdawg24
Jun 1, 2011 08:43 AM
95_993
Dec 6, 2010 08:42 PM
Emilgevor
Aug 13, 2009 10:57 AM
