Vag com troubles
OK, so i have an 05 a6 4.2l (c6) I know it uses the CAN version of diag. Has anyone been able to use VAG COM to connect to this car if not any other software suggestions?
I bought this cable of e-bay it is written on this cable VAG-K+CAN in red letters
I can get this thing to work but when i connect it to the car it states "no reply from controller"
Any help with this would be greatly appreciated
Thanks in advance
Thanks in advance
Ross Tech actually states on their site that no aftermarket cables will work w/ their software on a CAN car. I highly doubt there is any aftermarket software out that will work on a CAN car w/ the exception of Ross Tech or a generic OBDII reader - which isn't going to tell you much.
Too bad you're so far away - I'd help you out. In the meantime, check out vagtoolfinder.com - I'm sure there is someone nearby
