Valve Cover Gasket Replacement Questions, work in progress..
Old Sep 2, 2009 | 09:38 AM
  #41
Jackmup's Avatar
Originally Posted by gwos25
How complicated is that part? Can it simply (lol, like anything is simple on this car) be removed and cleaned, or should it be replaced? I can get it for $91, but if it's just a cover/vent with no parts that would fail anyway, then I'll just clean it. Anything else I might run into getting to this part? Suction jet pump? Should it be replaced too? I was going to, but then couldn't find it, but looking at the manual, it looks like its under the manifold, which is going to have to come off to get at the crankcase vent. So... While you're in there... I'm glad the weather's been nice, at least my motorcycle's been getting some use!
Thanks,
Wow that's pretty clogged, Now I'll have to order a valley pan gasket for mine as well. I haven't taken one off, Chefro just did his he might know or auditech79 would know. I'll PM them and find out.
You may want to work on installing a catch can, it routes the vent lines into a canister where the carbon particles are filtered out and left in the can. You would have to read up on them because you need to design it for your own car. Then again that has most likely been building up since it was new so it may be another 100k before it would happen again.
Old Sep 6, 2009 | 05:49 AM
  #42
m000035's Avatar
I am making sure the dip stick tube isn't sealed until I can check if there is pressure building in the crank case. I saw a procedure, just need to find it.
If there is pressure building in the crank case under boost, I'll have to go into the spider hose, crank case vent and PVC check valves.
Old Sep 6, 2009 | 01:18 PM
  #43
chefro's Avatar
In the C4 I don't have that crankase ventilation valve. In the valley pan are two oil retention valves, which presumably must be replaced if the valvetrain sounds noisy on short drives, although the noise may go away on longer drives.
Since you said the intake manifold has to come off to get to it, the crankcase ventilation valve looks like something it probably sits on top of the valley pan, instead of the C4's simple cover. I would definitely remove it and clean it, versus replacing it. The gasket is pretty cheap ($ 4-6). You may need new manifold gaskets to the heads, though, if you choose to clean it and remove the manifold.
If you remove the manifold, you may consider cleaning the throttle body as well.
SeeVon3
Apr 14, 2011 10:04 AM
mikeeboy82
May 2, 2009 11:48 PM
robert.jones
Dec 10, 2008 08:01 AM
robert.jones
Dec 10, 2008 07:56 AM
donsupreme
Mar 27, 2006 07:34 PM
