Valve cover gaskets keep leaking
Old Feb 11, 2007 | 01:56 AM
mikehh's Avatar
Default Valve cover gaskets keep leaking
i changed my valve cover gaskets twice now on my 00 a6 avant and they keep leaking. i thought it might have to do with some pressure building up in the crankcase that cant be vented properly and changed this awfully brittle vent tubing also. for a while i had an error code for "EVAP flow insufficient". any connection? Also, i noticed that in the summer it semmed as if the engine was knocking at times. any connection???
any input is appreciated!
Old Feb 11, 2007 | 03:25 AM
modset's Avatar
Default RE: Valve cover gaskets keep leaking
did you also change your cam chain tensioner/gaskets. more than not, that's where the leaks come from.
Old Feb 12, 2007 | 09:55 AM
mikehh's Avatar
i did not as i thought i have to ake out the cam somewhat. the cam gasket was only some $20 i think, but i wasnt sure if i should change it.
Old Feb 12, 2007 | 02:29 PM
madridlover's Avatar
Do a search on www.audiworld.com. There are a lot of posts on changing the camchain tensioner gaskets without having to take the chain out. There is a special tool you need to buy to do it. It's called a 3366 tool.
I changed my valve cover gaskets out 2 weeks ago along with the suction pump and breather hose and I still have an oil leak. I'm going to go back in and change the tensioner seals this time and see if that fixes my problem.
AudiA8driver
Jul 1, 2014 11:20 PM
mradams316
Oct 16, 2011 11:47 PM
06AFOUR
B7 Models
Jan 5, 2011 03:33 PM
cwedholm1
Nov 3, 2009 09:03 AM
