Vibrating while driving
Old Feb 16, 2009 | 02:49 PM
Ajay4u's Avatar
Default Vibrating while driving
My Audi A6 vibrates when i drive. when i applyies the brakes and car get slow it vibrates more and it is very annoying. I have checked the tires for low air but nothing wrong. This bubbling of the car is increasing day by day and the only thing that I know is the rear tires are about to worn and I have been suggested the tires change and also the brake pad changes. I just wanted to know is this only becuase of this or could be something else?
Old Feb 16, 2009 | 07:13 PM
zippy_gg's Avatar
In addition to the aforementioned brake pads (and rotors) and tires, I would also check for torn CV Joint boots. Just rub your hand on the inside of each wheel; if you come out witha bunch of grease you have a winner - well... not really, but you may have found the source of your vibration. As the boot tore and lost the grease in it the joint starts to wear out and rubs metal to metal without any lubrication.
Old Feb 16, 2009 | 07:18 PM
oc_audica's Avatar
tie rods or control arms tend to wear by now also (guessing you have an 02-04 A6 2.7t)
Old Feb 16, 2009 | 09:33 PM
99A6Q's Avatar
brake rotors being warrped is causing your pulsation when breaking. If your tires are worn, replace them, they are probably out of balance causing a vibration also.
KBNYA4
Aug 8, 2015 10:16 AM
ProJectB5
Apr 10, 2011 02:24 AM
cayod5
May 31, 2010 06:18 AM
grandrapidsaudi4life
Dec 21, 2008 09:53 PM
thintzen
Mar 4, 2005 05:28 PM
