Want to add performance to my 2.7T. LI, NY
Old Mar 29, 2007 | 09:39 PM
ppgoal's Avatar
Default RE: Want to add performance to my 2.7T. LI, NY
I've been very happy with the GIAC chip, installed at 74k, along with the Bailey diverter valves and Samco TBB. No problems with the engine, now at 94k. I had no difference in fuel consumption while driving conservatively, but there is a huge difference in power - almost a surge that pushes you back in the seat - when I step on it above 3000 rpm. The downside - I had to replace the clutch and flywheel at 89k. It seems to get better fuel economy by a smidge with the lightweight flywheel.
As suggested above, make sure you change the oil regularly and let it warm up and cool down. I looked into the downpipes and decided against them - just not in the mood to replace a perfectly good exhaust system right now. I suppose at some point a turbo may fail, but I hope it's not for a long time if I treat them right. If I have to replace them, it might be a good excuse to upgrade to K04s.
Old Mar 30, 2007 | 08:37 PM
twinturbomew's Avatar
the first thing you should do is take notes on southturbo and all the other advice. there are a few mantience things you should get to assure you enjoy the car.
1 new APR bi pipe
2 dv's nothing spical here don't spend the big money for unnecessary parts get the 710n dv's there is nothing better for your money
3 get Dp's vastperformance has good ones for 400$ they all do the same thing other companys have them but you will spend 3 times more for the same performance
4 look on the second page of threds in this forum for the sugestions for the 2.7t owner. give it a bump as there is a lot of other info in there for you to use and help direct you
5 DON'T get a superchip chip they do not have large market share in the 2.7 market the money you save will not be worth the lack of local suport. I suggest a GIAC chip mine has served me quite well
brownstud08
Sep 3, 2008 07:00 PM
agunst9
Aug 26, 2008 07:50 PM
Wintermute
Sep 18, 2007 09:49 AM
audiant
Oct 18, 2006 10:43 AM
Quaberto
Sep 24, 2006 07:40 AM
