waterpump question.
Old Nov 22, 2009 | 11:17 PM
Midniteoyl's Avatar
Where the lower coolant hose goes?
Old Nov 22, 2009 | 11:19 PM
Midniteoyl's Avatar
Not the lower hose from the radiator, but the smaller one that cuts all the way back to the expansion tank... Diagram calls it the 'lower coolant line'.
Old Nov 22, 2009 | 11:23 PM
Midniteoyl's Avatar
Looks like theres a line heading to the right (pass side) turbo from the same area... not real sure though.
Old Nov 23, 2009 | 01:33 PM
GDET09's Avatar
Idk its a really small leak. very thin then drips and if i drive the car alittle it will continue if had stopped. It drips somewhere and drops from the oil reservoir, where the oil is drained. Ill post a picture.
Old Nov 24, 2009 | 02:24 AM
GDET09's Avatar
for anyone that has done the TB replacment or knows of it. How does the Thermostat O-ring go on? In front of it or behind the thermostat?
Old Jan 29, 2010 | 02:07 AM
emmwhat's Avatar
in the b5 s4 it goes
thermostat housing >> o-ring >> thermostat >> engine
I'm guess it would be the same design
Old Jan 29, 2010 | 09:14 AM
bob martin's Avatar
Per the Society of Automotive Engineers, the right side of the car is where the passenger sits in the US and China. The left is where the driver sits. A leak on the passenger side could be your lower radiator hose not all the way on, but these tend to be big leaks, not little ones. It could be a transfer hose that sits there. Or, it could be your t-stat housing leaking and the water is running down the lower radiator hose pipe. A good way to narrow down the source is spray foot powder. Dry everything you can reach then spray it with foor powder. The water will be highly noticeable as it disolves the foot powder. Then, trace the water to its source.
Good luck. These can be difficult to find.
Bob
brese73
Apr 14, 2012 01:44 PM
tipstall
Audi Q5
Dec 24, 2010 11:34 AM
sshhbequiet
Dec 23, 2010 09:26 AM
bradtyler02
Aug 19, 2010 05:48 PM
Got2Speed
Sep 10, 2008 11:52 PM
