What The Heck Is This !!!!
Old Sep 19, 2012 | 06:25 PM
Luisthehomie's Avatar
Default What The Heck Is This !!!!
i got codes
p1131
p0160
p1423
p1113
and my fuel gauges doesnt work either it just stop working mysteriously
please can any one tell me what these ropes are and how can i fix them before i get ripped off
thanks in advance
Attached Thumbnails What The Heck Is This !!!!-imag0258.jpg   What The Heck Is This !!!!-imag0253.jpg   What The Heck Is This !!!!-imag0255.jpg   What The Heck Is This !!!!-imag0257.jpg   What The Heck Is This !!!!-imag0256.jpg
Old Sep 19, 2012 | 09:00 PM
z28pete's Avatar
P1131-- Bank2-Sensor1 Internal Resistance too High, Upstream (primary) O2 sensor bad
P0160-- O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected, may clear if other problems are fixed.
P1423-- Sec.Air Inj.Sys.,Bank1 Flow too Low
P1113-- Bank1-Sensor1 Internal Resistance too High
1) Looks like both upstream O2 sensors have problems with their heater circuit (check fuses, wiring, & connectors), it is unlikely that both O2s failed at the same time.
2) AIR pump is not feeding enough air into exhaust. Check fuse for AIR pump, wiring and connectors, and hoses going from pump to exhaust system.
Old Sep 20, 2012 | 07:18 AM
ratherb1's Avatar
That braided line looks like it goes to the fpr ( fuel pressure regulator)
Old Sep 20, 2012 | 04:44 PM
eazy211187's Avatar
Sounds and looks like your Vacuum line need to be replace. The vacuum line with set off those codes. The fuel gauges try the fuses.
Old Sep 21, 2012 | 12:22 AM
Could this be causing my fuel guages to stop working?
Also if it's a fuse which on is it?
Joe Dirt
Dec 27, 2011 11:02 AM
y^0
Mar 4, 2010 08:24 AM
bottlecap
Nov 3, 2009 12:57 PM
oscar_3
Mar 29, 2005 01:40 PM
