What performance part 1st?
Old Aug 9, 2007 | 10:21 PM
DjDiddles's Avatar
Default What performance part 1st?
I got my A6 about a month ago and want some more power but on a tight budget! Anybody know what I can put on to give me some more power? I've seen the ECU chips, new exhaust, but don't know what else. I have the 2.7T. Thanks!!!
Old Aug 10, 2007 | 09:51 AM
alias747's Avatar
Default RE: What performance part 1st?
Diverter valves and then chip. Biggest bang for the buck mod, without a doubt.
Old Aug 10, 2007 | 03:49 PM
ppgoal's Avatar
Significant performance increase (250 to 318 hp) from a chip. Plan on replacing the diverter valve and throttle body boot at the same time with heavier duty parts to avoid problems caused by higher boost. Count on around $1000 for parts and labor. Sounds like a lot, but nothing but nothing will get you 30% more hp for this price.
Old Aug 10, 2007 | 05:50 PM
twinturbomew's Avatar
2nd that get Dv's
don't get suckered by the expencive Dv's get a set of 710n Dv's they are the best for the money people are making over 450whp with them so don't be foolish and waste your money.
I always tell people about Dp's they are the next best things to save your turbo.
at 400$ there is no reason not to get them. also when you get a chip get one of the new versions where you can adjust your boost so you can turn down the boost if you wish.
look to vastperformance for both
Old Nov 7, 2007 | 09:52 AM
Tha Abbot's Avatar
I have a question about the diverter valves.In this like https://www.audiforums.com/m_531160/tm.htm,
I tooka quotefrom the link above, the dude said"WhenI turned my dv around backwards it held 2x as much boost.I ran it on my t3t4 for a long time pusing 25psi" Is that true?
DiscoJaker
Dec 2, 2020 02:16 AM
brownstud08
Sep 3, 2008 07:00 PM
The Bosno
May 6, 2008 10:26 AM
Jamian
Feb 15, 2005 01:14 AM
