Which Performance Part to Add?
Old May 3, 2008 | 07:28 PM
The Bosno's Avatar
Default Which Performance Part to Add?
Hello to all. As you can see, I'm new to these forums.
I just bought a 2001 Audi A4 1.8ta month ago.
I was thinking of installing a intercooler and a cold air intakebut I don't know if that's the best first update. Will it increase my hp by alot or not.
Also what is the best thing to do to decrease the turbo lag.
Old May 3, 2008 | 07:36 PM
cincyTT's Avatar
I'm make believe
Default RE: Which Performance Part to Add?
please see the newbie guide in the A4 main section.
BTW, the car has NO TURBO LAG!!
Old May 3, 2008 | 08:36 PM
The Bosno's Avatar
Then there must be something wrong because when I bring the rpm's up the car loses power suddenly.
Old May 3, 2008 | 09:33 PM
ImTheDevil's Avatar
That wouldn't be turbo lag then. The lag is when there's a delay between hitting the gas and the boost hitting. As cincy said, the 1.8T is about as lagless as a turbo engine will get. Go to AutoZone and have them scan your car's ECU for codes - you may have a latent code in there that isn't triggering a check-engine light. If there is, post it here in reply and we can try to work you through it.
Old May 3, 2008 | 10:12 PM
fred2ka4's Avatar
after market intakes do not do a whole lot unless you are BT = Big Turbo so that would not be a first mod that I would consider. Your intercooler also has to be considered because you don't want to waste money. If you pick an intercooler that works well with your current set-up, (stock) and then decide to go BT you may have to do it again. And if you decide to go with a bigger intercooler to handle your future needs, it may cost you some performance in the short term. I would consider chipping the car and maybe getting an aftermarket exhaust first and then move on to some of the other items.
But as suggested, you need to first find out what's wrong with your car before you start modding. One of the most important first things that you can buy for your car, especially for an Audi that you intend to mod, is a Rosstech Vag-Com cable.
Old May 4, 2008 | 05:00 PM
Mike-2ptzero's Avatar
ORIGINAL: The Bosno
This is while you are going WOT?
Old May 5, 2008 | 04:07 PM
The Bosno's Avatar
THis is while I'm driving and when i bring up the rpms to 4000 especially in 1st but also in 2nd, it seems like it loses power suddenly, then gains it again.
Old May 5, 2008 | 10:43 PM
oldgearhead's Avatar
Dollar for dollar, I have to say diode mod with a boost guage and manual boost controller. Best mod for the money I've ever had! Check out cincytt's post on it. Search on 'cheap power'.
And btw - thank you cincy! I've had mine modded for a few months now, and it is a different car!
https://www.audiforums.com/m_535568/tm.htm
Old May 6, 2008 | 10:26 AM
ORIGINAL: oldgearhead
Cheap now. Still the best way to get max power at a low cost is going with a GIAC xchip which pushes the K03 on the 2001 to 18-21psi and still keeps the over boost safety of the map sensor which the diode mod deletes.
I will let you guess who was the first person to do a Diodeon the dbw cars.[sm=guilty.gif]
DiscoJaker
Dec 2, 2020 02:16 AM
brownstud08
Sep 3, 2008 07:00 PM
DjDiddles
Nov 7, 2007 09:52 AM
Jamian
Feb 15, 2005 01:14 AM
