What size rotor do I have?
Old Nov 6, 2007 | 10:05 PM
madridlover's Avatar
Default What size rotor do I have?
Okay, I have a 98 2.8L Quattro and I'm needing to change out my brake rotors and pads. However I'm not sure which size to buy. Do I buy the 288mm, 312mm, or 321mm rotors. How does one tell?
I can tell you that I have 16" rims if that helps.
Thanks in advance.
Old Nov 7, 2007 | 01:49 AM
Nocturnal_A62.7's Avatar
Default RE: What size rotor do I have?
312 for front, and 245 for rear. This the company spec.
Old Nov 7, 2007 | 10:00 AM
daroshi's Avatar
Early C5 (1998 was first year) with the 2.8 is most likely 288mm x 25 mm. If you're not sure, remove a front wheel and measure the diameter.
288mm = 11.3"
312mm = 12.3"
321mm = 12.6"
ECS has lots of listings http://www.ecstuning.com/stage/edpd/...ubcategory=OEM
Old Nov 7, 2007 | 11:30 AM
Daroshi, you are correct sir. I just called my dealer to make sure and based on my VIN number the parts guy said i have the 288mm front rotors.
Thanks guys for the replies.
mblayton
Sep 5, 2017 10:45 PM
saifxnyc
Oct 14, 2012 05:35 PM
snow6
Jan 21, 2012 10:33 PM
spex
B7 Models
May 1, 2008 11:26 PM
armani1608
Feb 2, 2007 02:00 AM
