WHAT IN THE WORLD IS THAT NOISE!!!!
Old Mar 12, 2007 | 05:58 PM
jcolon68's Avatar
Default WHAT IN THE WORLD IS THAT NOISE!!!!
Ok, I have a 2001 Audi A6 2.8L ... The car is making a high pitch noise coming from the engine compartment. Someone told me it seems to be the Powersteering pump..the noise pitch does change when I turn the wheel... This thing is driving me insane... Anyone has any thoughts??? Is there any way to test the powersteering pump or disable it to rule it out? I guess it would be difficult since you would have to remove the belt....
PLEASE ..ANYONE!!??
Old Mar 13, 2007 | 02:50 AM
Vaudi's Avatar
Default RE: WHAT IN THE WORLD IS THAT NOISE!!!!
check the pwr steering fluid level.
Old Mar 13, 2007 | 12:37 PM
jcolon68's Avatar
I actually flushed the power steering fluid and put new fluid. Still same problem..
Old Mar 13, 2007 | 02:34 PM
jcolon68's Avatar
57 views and one reply??? Anyone else pls??
Old Mar 13, 2007 | 03:45 PM
techbod's Avatar
low fluid level - power steering pump - power steering belt too loose or worn
Old Mar 31, 2007 | 01:32 AM
k.sinclair's Avatar
I am having a high pitch noise on cold starts near the back of the engine compartment, and it sounds like it's the air pump. Where is your sound coming from in the engine??
Old Mar 31, 2007 | 12:38 PM
atorreon's Avatar
i had the same noise and it was the power steering pump/fluid level
Old Mar 31, 2007 | 05:33 PM
GIAudi's Avatar
I had the noise and had to replace the pump. Not to hard to do either. Pumps are about $100 used. I picked one up with 20K miles and it has been great. If it isn't that, I had a weird noise and it was the alternator failing.
Old Aug 18, 2007 | 11:20 AM
0 0 0's Avatar
where did u get the used pump for 100 bucks?
SidewaysTim
Sep 19, 2011 09:13 AM
pipemitten
Feb 23, 2009 10:39 AM
ezlnh8u
Oct 28, 2007 06:07 PM
haston
Dec 18, 2006 06:07 PM
a224932
Feb 16, 2005 02:05 PM
