What's that? Rubber hose with a bolt on it around coolant tank area
Hi, I accidentally found a rubber hose with a bolt on it, hanging free around the coolant tank area. The other side appears to go into the firewall. I amjust wondering what that baby is and where should it go? It's a 2000 A6 2.7t Tip. Thank you very much! I pulled it out a little bit and took a picture, as attached. Here is also what appears to be one the hose. I can't find the part based on the number though (because of wrong part number originally, infoadded later).
8D0 121 428 >AEM< (This is the correct part number, info added later)
ZD 25.03.98 1q00
[IMG]local://upfiles/44237/ACDBCE2AEC344485A731587F3D6EB550.jpg[/IMG]
ZD 25.03.98 1q00
If it comes out of the bottom of the reservoir its a drain hose for the overflow in case the car overheats. If it were a coolant hose it would be puking coolant all over the place.
GBP
B7 Models
Feb 25, 2013 11:49 AM
sm937
Jan 21, 2013 10:19 AM
