When I lock the car, is it supposed to beep?
Old May 29, 2007 | 11:27 PM
A1C Basinger's Avatar
Default When I lock the car, is it supposed to beep?
Whenever I lock my 2000, I hear it lock, and then hear a very FAINT honk. Is it supposed to make a noise of somekind? Sounds like whatever it is that does it went bad. Any ideas?
Old May 29, 2007 | 11:42 PM
alias747's Avatar
Default RE: When I lock the car, is it supposed to beep?
Yes its supposed to, mines not real loud either, but loud enough.
saintforlife's Avatar
I have the same problem with my '03 A6. I can barely hear it from 5 feet away. I find itamusing thatAudi decided to put a $5 (it sounds cheap)central locking alarm on a car with relatively sophisticated electronics. Does anybody know a work around to this? Is itpossible to install a better/louder beeper?
Old May 29, 2007 | 11:46 PM
alias747's Avatar
I loved the aftermarket alarm that my A4 had, it chirped pretty loud! It just sounds cool!
Old Jun 2, 2007 | 11:27 AM
Rodneylynn1977's Avatar
My 2003 A6 is the same way. My girlfriend laughs every time I lock the car. It almost sounds as if the battery is like dead or something!!!
Old Jun 2, 2007 | 11:58 AM
zymol's Avatar
It's a simple horn device that sounds like a sick horn. Hold the red panic button to hear it in all its glory!! I've been told it can be replaced by another horn/chirp device like the chirp found on a Lexus or the subarus. (very high pitched, and sound expensive.) Also the alarm horns from the VW touareg are another sweet option. All you have to do is determine your signal type to the alarm horn module ( ie. constant voltage, pulse width modulated, or pulsed voltage signal.) then get a new horn that will work with the same signal.
P.S. I am going to do this on my Audi, but so far the alarm horn modules I have searched for are pretty expensive, so I've still not done it yet.
Old Jun 5, 2007 | 12:49 PM
varini100's Avatar
same faint noise
suresh03223
Oct 8, 2013 03:47 PM
Tremar
Jul 26, 2012 12:32 PM
planetnb
Feb 29, 2008 04:57 AM
betz470
Jun 2, 2007 01:08 AM
