Will the car ECU system damage if I disconnect battery?
Old Apr 16, 2010 | 05:33 PM
inventorA6's Avatar
Default Will the car ECU system damage if I disconnect battery?
Hi,
Somewhere else in the forum, I am asking whether the 2001 audi a6 car battery is bad or there is a leak.
So, I decided to remove the negative cable, so that if there is a leak, the battery should be able to run the car next time,
My battery drains, if not used for 3 days in a row.
So,
my question is:
If i disconnect - negative terminal, will the ECU forget everything? like power windows alarm etc? Is it hazardous to the car? I will reconnect it the next time, I need it. I only need my car on weekends.
I know radio memory seats will be deleted, I don't care about that, I was just wondering, is it a good way to prevent the battery to run out, when the car is not being used.
Thanks in advance.
Old Apr 16, 2010 | 06:18 PM
jhuffman's Avatar
You should be ok, but an electrical leak will get old in a hurry. what if you forget to disconnect it one time and cant get it started when you need it?
YorkshireAudiA3
May 20, 2015 08:18 PM
KarlosFandango
B7 Models
Aug 9, 2012 12:04 PM
iheartboost
Nov 12, 2008 11:02 PM
04A6RGR
Oct 22, 2008 11:41 AM
shabbey
Sep 28, 2004 01:23 AM
