Will a p0411 clear on its own after a repair or do I have to manually clear it?
I have had the same issue; I cleared the cell and two days later it came back. I read somewhere that the coolant temp sensor could be the fault. I looked it up online and the OEM sensor costs about $25 and the diy is very easy. I'm about to order the part now and will update if it solves the issue; don't forget to update us as well.
Did you find the solution yet?
I just noticed you had this thread going too, Copper.
Did you replace the pump because it had stopped working and you confirmed that it had stopped working?
If the pump goes for a while without working (I let mine go a year... yes, a year!) without working until it was time for inspection. That allowed my passenger side combi valve to seize, producing similar issues like you are seeing.
I'm not saying it's a sure thing that you're seeing the same issue, but certainly worth thinking about if your pump wasn't working for some time.
I replaced the temp sensor; reset the CEL and a day later it came back. I will take it my one of my mechanics to see if he can find the cure. I will update soon.
This cursed code. I hope the solution does not end up costing a bunch to fix.
