Will a p0411 clear on its own after a repair or do I have to manually clear it?
Old Mar 2, 2012 | 06:50 PM
greatlakes40's Avatar
Originally Posted by copper07
I will give it a try to see if one on those valves is bad. I really want to get rid of the p0411.
Did you find the solution yet?
I have had the same issue; I cleared the cell and two days later it came back. I read somewhere that the coolant temp sensor could be the fault. I looked it up online and the OEM sensor costs about $25 and the diy is very easy. I'm about to order the part now and will update if it solves the issue; don't forget to update us as well.
Old Mar 5, 2012 | 12:12 PM
copper07's Avatar
No I still have not found the fix yet. It is very frustrating. Let me know if swapping the coolant temp sensor fixes it? Do you have a picture of where that sensor is located, then I could check and see what that looks like on my car?
Old Mar 5, 2012 | 03:29 PM
Nebuchadnezzar's Avatar
I just noticed you had this thread going too, Copper.
Did you replace the pump because it had stopped working and you confirmed that it had stopped working?
If the pump goes for a while without working (I let mine go a year... yes, a year!) without working until it was time for inspection. That allowed my passenger side combi valve to seize, producing similar issues like you are seeing.
I'm not saying it's a sure thing that you're seeing the same issue, but certainly worth thinking about if your pump wasn't working for some time.
Old Mar 5, 2012 | 03:57 PM
copper07's Avatar
The pump was still working when I replaced it, but I was told by a shop that the housing on the pump had failed and that was the reason for the p0411. I swapped out the plump reset the code. It was gone for a few days but returned. Now I'm back on the hunt to resolve the issue. I will definitely check the combi valve to see if that is the issue.
Old Apr 16, 2012 | 08:40 PM
I replaced the temp sensor; reset the CEL and a day later it came back. I will take it my one of my mechanics to see if he can find the cure. I will update soon.
Old Apr 17, 2012 | 11:21 AM
copper07's Avatar
This cursed code. I hope the solution does not end up costing a bunch to fix.
alexmurphy
Nov 25, 2010 04:19 AM
Gigantor
Aug 26, 2009 07:00 PM
d2mini
Aug 8, 2007 09:46 PM
a88fl1
Jun 28, 2007 04:50 PM
johnnyspade
Jul 28, 2005 08:31 PM
