Will this work on a A6
Old Mar 27, 2012 | 05:57 PM
Jenssy's Avatar
Default Will this work on a A6
Front brake pad wear sensor - Page 4 - TDIClub Forums
I have a brake pad wear sensor on and it wont go away even after putting on the new pads. Looks like it was ripped off.
my car is a 99 A6 Quattro
I also attached a pic of the instrument cluster from the link
Old Mar 27, 2012 | 06:49 PM
nm3210's Avatar
Why did you attach a completely unrelated instrument cluster??
The brake pad sensor is just a continuity check, if the connection is broke it will report the brake pad as warn and if there is a solid connection it will think there is plenty of brake pad left. You can just short the connection with a wire/splice or something (depending on whether you want to use the connector again). Keep in mind that if the wire is open/broke anywhere along the route it will report as a warn brake pad.
I'm not sure about the vag-com fix and have not come across it before (and i've done a lot with vag-com and frequently use it).
Old Mar 27, 2012 | 06:53 PM
02A6Beau's Avatar
exactly this
mmhyson
Jun 8, 2009 07:19 PM
971.8t
Mar 27, 2008 01:07 PM
quattrocket
Nov 22, 2005 04:45 PM
