Yellowish cream in engine oil?
Old Jan 19, 2009 | 11:53 AM
james0013's Avatar
Originally Posted by ppgoal
As stated, a little bit can be due to condensation from external temperature changes. A good, long high speed drive should evaporate it from your oil. I would also recommend an oil change using synthetic -- it seems more resistant to this problem. If it appears again soon after the oil change, then you might have a head gasket leak.
Short trips in cold weather are hard on a car. Note how water will drip out the tail pipe -- this is one byproduct of combustion and only driving enough to thoroughly heat the engine and oil will eliminate it.
I have only used Mobil one Synthetic oils since I got the car. I am also having them change the oil as I am due for an change (80,000 miles).
twopedalwarrior
Apr 18, 2013 07:41 PM
avantgradeA6
Nov 17, 2007 07:37 PM
98jeep5nine
Jul 4, 2007 04:21 PM
my nh a4
Aug 3, 2005 05:12 AM
paradocs
Dec 30, 2003 01:17 PM
