Audi A7 Athletic, elegant and dramatic, the Audi A7 is a five-door coupe with the graceful look of a benchmark luxury sedan.
Heated Steering Wheel
Old Oct 22, 2011 | 07:06 AM
Hdman1216's Avatar
Default Heated Steering Wheel
Is there something more I need to do to get the steering wheel to heat-up?
I press the button and it says on, but no heat. The owner manual says
that it has something to do with programming the key. WTF
Old Nov 10, 2011 | 02:00 PM
Audi_Eric's Avatar
Strange - it could be that it's not connected properly. My Q7 had that issue. A7 is working perfectly - it's getting cold here
Old Dec 2, 2011 | 03:03 PM
Audisteele's Avatar
Any luck? I can tell you I had an A7 for the weekend and I thought the steering wheel did not get as warm as it should. It also seemed to be warmer on the left side of the wheel. Odd. I will try a couple other A7 wheels and report back.
Old Jan 12, 2012 | 09:40 PM
Audi Tek's Avatar
Tech Certified
i believe the ambient temperature outside may have to be below a certain temp. thats the way it used to work before the button was added
Old Feb 12, 2012 | 09:17 AM
viggense's Avatar
I have been reading about this issue in several forums (I got the cold weather package and expect delivery in May). They all say it depends on the ambient temperature; the colder it is the warmer the wheel. Owners also say the elements are near the 10 and 2 positions and it takes a little time to heat the entire wheel.
Lazydog
Dec 26, 2012 11:27 AM
fischgrape
Dec 21, 2007 10:27 PM
munkee
Mar 1, 2007 09:45 AM
kbraganca
Dec 4, 2006 03:16 AM
Alisajp
Oct 31, 2004 11:25 PM
